All
Are the standard ford water pumps up to the task of circulating coolant in a GT40? I am using the standard reverse direction (serpentine) pump which came with the 302W engine. As the engine warms up it starts to make a noise like a kettle, which is very worrying. This noise starts before the thermostat opens. As soon as I increase the revs the noise goes away. The engine has been bled many times now and I do not think there is too much air in the system but this noise persists. I have just tried it with the thermostat removed and it has improved a little but not much.
The only conclusion I can reach is the coolant flow rate is so low that the water is boiling in the heads at idle. The overall coolant temperature is in fact OK. The temp gauge and the ECU temp sensor both say the temperatures are within limits.
Should I be looking at another pump. If so any recomendations?
Regards
John
Regards
John
