Fran, I'm in. She's sexy.
A few questions for ya when you have a "spare" moment.
- Power steering?
- Power brakes?
- Gauge cluster... Eclipse, VW/Audi B5 platform adapted or aftermarket provided with kit?
Right now I'm assuming she's set up for manual steering & brakes like your other cars and is utilizing the stock Mitsu cluster.
Need to know these items so I know what I can toss or have to modify or keep on the Audi 2.7 twin turbo I'm building. I should be transferring a few Quid from my wallet to yours for an Apex this spring. It's the slow season for my business right now so I need to sit on my wallet for a bit. Sorry.
My plans so far:
- Audi 2.7 bored and stroked to 3.0 target 700-800 hp (crank) looking for about 550 - 600 RWHP.
- Twin GT2871 turbos set up like Audi R8 and Lamborghini aftermarket turbo kits
- Air/Water after-coolers with dual heat exchangers in the openings up front beside the radiator opening.
- Intake flipped with throttle body at back.
- 80mm Hemi throttle body
- VIPEC ECU
- Flex fuel
- Bolt Action 5 speed tranny.
- 7500 RPM redline ... (That's 204 mph with $300 DVZ code 5 speed):lipsrsealed:
- Stock GM Z06 wheels
- Orange paint with a gold pearl and some flat black accents.
- Black with orange inserts leather interior with a touch of carbon fiber bits.
The $500 eBay engine I have went from a mild freshening up to Lambo killer 700-800 hp 3.0 stroker build when it failed compression and leak-down tests. Stuck rings and scored bore on #2, a cracked oil pump and galling on all the valve stems on the 1-3 cylinder head is what I found.
Block's at the machine shop now getting tanked and poked out to an 83mm bore, stroker crank and chrome moly H beam rods are in and waiting for some custom JE pistons. I can't wait to see this block with some POR Ford T-Bird red on it. That's gonna be pretty with all the aluminum bits on this engine ... and a lack of all the extra unneeded OEM bits and EPA garbage hiding it.
Thinking about starting a build thread but right now all I could show is about 12 shelves of parts, a 30 gallon trash can full of parts I've thrown away tearing down this engine and share some, stories, tech tips and research I've done recently.
This is the photoshop that sealed the deal for me.. Your reputation doesn't hurt either. Me, I plan to paint the splitter too. Like many have done on the Ferrari 348, painting the front spoiler body color vs the factory black changes the whole look of the car for the better IMHO.
The Apex is as low as the BMW Z4 I recently sold and looks like the approach and departure angles are very similar so I know for a fact that the splitter on a daily driver will eat an occassional steep driveway and have some parking curb oops that will need to be repaired now and then.
