Turbo cars were quite common, especially in the earlier years (95-97) and they now represent most of the survivors. That is because Non Turbos were rarely enthusiast’s cars, so after certain age they were discarded after first major failure.
But the body, itself is the same, the difference is in the engine harness/ECU. You could find a clean (southern) NT donor for the body (probably under $1k) and then buy beat, but modified Turbo/AWD car for the rest of the parts.
If you are willing to put in the effort, you should be able to part out and sell the parts/mods from the modified AWD car to offset your donor cost. There are many valuable parts that would not be needed on the Apex, but are thought after by DSMers.
In the end, most people will want to use ECM Link for the engine management. ECM Link is based on ’95 ECU. In some states, you might have a problem with having ’95 ECU in ’96-99 cars. So, check first about your state regulation. That might dictate which year shell you should start with to make your life easier in the end.
IMO, an ideal donor will be ’95 AWD car:
- Pre OBD2 requirement – easier inspection in most states.
- Thought after E-prom OBD2 ECU (Yes, OBD2 in ’95, even though it wasn’t required until ‘96)
- AWD transmission (most likely used in APEX)
- AWD parts to sell to DSMers (transfer case, driveshaft, rear end, fuel pump ASSY: ~$500-700 worth of parts, depending on condition)
