J John Cohen Apr 3, 2016 #1 Hi all another question ......LOL ...... What temp stat should I get ? are you running one or leaving it out .?? Thanks guys .....:worried:
Rick Muck- Mark IV GT40s Sponsor Supporter Apr 3, 2016 #2 Use a 180. Most engine builders will never suggest no stat. You need the restriction to slow the coolant flow down to allow for heat transfer.
Scott Calabro Apr 3, 2016 #3 mark iv said: use a 180. Most engine builders will never suggest no stat. You need the restriction to slow the coolant flow down to allow for heat transfer. Click to expand... +1 (82*c) Although drilling a #30 hole in it helps to continually bleed any trapped air to the expansion tank.
J John Cohen Apr 3, 2016 #4 Brilliant guys a big help ..... I love this forum ......So helpful .... John
Rick Muck- Mark IV GT40s Sponsor Supporter Apr 3, 2016 #5 Scott Calabro said: +1 (82*c) Although drilling a #30 hole in it helps to continually bleed any trapped air to the expansion tank. Click to expand... Scott, Good point. We do that but I forgot to mention it. The hole makes filling/bleeding much easier and is good practice on GTs where the cooling system is long and complex.
