Having got the MOT on the Tornado on Saturday, I thought I would take it for a short drive. After a few miles I approached a roundabout and the brakes worked ok but once I released the pedal (still moving) the brakes continued to grab and within 20 feet the car ground to a halt. On inspection I found the fronts were completely locked on and further investigation revealed the problem was the brake servo not letting go. Once I prised out the one way valve the brakes released and all was fine. No air could pass either way through the valve until I blew hard from the back of the valve and it then released. Installed the valve back in the servo and drove the car home with no problem. Not sure if the problem actually was caused by the valve or the valve locked because of a problem with the servo. The car had been stood for 2 years before I bought it and has a separate remote brake servo for the front and rear brakes.
Any pointers would be welcome.
Trevor.
Trevor.
