If you've installed a traction control system such as the Racelogic system, how did you mount the rear wheel speed sensors? Did you use the CV joint bolts as pickups or did you install a toothed trigger wheel? If so, where did you mount the trigger wheel and sensors?
I need to use VR sensors, not Hall, and my leading candidate for a mounting solution is to use a toothed trigger wheel on the transmission-side CV joint mounting flange along with a bracket that attaches to the transmission housing.
Any part ideas, mounting ideas, pictures, thoughts?
Thanks,
Tim
Thanks,
Tim
