I would defenitely give it a try. You never now what you will find out.
Í had a race weekend with my bike 2 years ago. On sunday morning my rear DUNLOP KR 164 was pretty good used and i wanted to safe it for the afternoon race. I use to have a second set of rims with me just in case. They are shoed with a complete different tire. The KR´s ( KR 825 front and KR 164 rear ) are soft compound vintage race tires, which actualy are run be every serious contender in my class, but they are a old construction concept. The front tire is pretty small in witdh and section height (2,75/3,75 -18) so overall diameter is very close to a modern 120/70/17 tire. THe rear. KR 164 is a 3,75/5,00-18 size on a 2,75" rim, so not the biggest tire also.
Beeing the lazy guy i´m, i did not want to change the complete set and left the front tire in and just replaced the rear with a modern Bridgestone BT012 tire in a big fat 160/60/18 Size on a 4" rim.
Everyone told me that i´m crazy , but i gave it a try and came back into the pits after the first session with a big big smile. THe bike was completely changed to the positiv. much more response in steering in, no underster at all anymore. I could carry much more speed into the turns and could accelerate earlier.
Make a long story short, i left this combo in for the race and won.
I modified this set up a little with a even more grippy BT090 in 150/60/18 on the rear, but the front is still the tiny KR 825. Happy with that combo since then.
If you don´t try you won´t know and if you are a decent driver and have a feeling for your car, your will feel if it works better or if it is better to go slow before you are in the critical area.
Usualy GT40´s are running a 215/60/15 in front when they are equipped with thhe CR6zz. This tire has only a contact witdh of 185 mm. So your 225 Yoko is probably a real 225 and will give you much more contact patch in front, which gives you probably more grip on the front ( if the compounds are similar). If the car was balanced before the car could be more prone to oversteer and you may end up to soften your rear swaybar to give it more grip at that end as well and achieving more corner speed over all. Just my theory for what it´s worth.
TOM
