Uprights, Rack/Pinion, Pedal box
I would like to buy original front and rear Uprights. (a copy made to oem specifications is ok).
I am also interested in an original Rack-and-pinion steering and a pedal box casting (again, copy is ok as long as they are identical to oem).
Best regards and have a nice weekend from Jonny.
Rick Muck- Mark IV
GT40s Sponsor
Contact Gelscoe: GT40 Parts Department | Gelscoe Motorsport
They can supply the original parts. The uprights we use on the Superformance are dimensionally and visually the same, but are cast in aluminum rather than magnesium and have different bearing sizes. The Superformance uses a steel rack housing instead of the FAV installed magnesium rack however the mountings are the same so you can add the mag rack to an SPF.
Hi Rick, thanks for Your reply :-).
Uprights from a Superformance could be an good alternative for me since I do not really care about the small weight difference, as long as it looks right, it is right to me ;-).
