Weber 48 IDA - Show me your linkages
favGT40 - Please don't muck up this thread. Take it to PM or eMail if you have a problem with me or anyone else here.
Thank you very much!
Mike Trusty
Not trying to change the subject or anything, but. Or is it actually back to the subject.
The attached photo shows the linkage that I use on injection systems. THe beauty of this arrangement is that it provides for a progressive rate of opening. This is due to the angel of the actuating links off of the bell crank close to the closed throttle position.
This is an injection system that I put together for a Pantera but the linkage geometry would be the same for Webers. The stand that the bell crank is supported on not only provides the right geometry location for the bell crank but it is a vacuum accumalator as well. This provides a good source for an average vacuum signal for the MAP sensor.
Do you think I am impressed with your lawnmower? Does it have a Briggs and Straton Engine?
What are you using for transaxle? Is it a twin cylinder?
Please refrain from making comments that are of a personal or derogatory nature. That is not what the forum is about.
John
show us a picture of your set up Fav. I for one would like to see how it is supposed to be done. Now if you just have drawings, I do not consider that much of an endorsement to your expertise. A good copy machine and viola, we can all be experts.
I have 2 sets of 58mm webers w/ crossover manifolds to trade you Chuck for your set of 48s if you want to get rid of them...
Just so you know what a real linkage looks like.
David Morton
O.M.G.
How sad.
Must include on my 'ignore list' from now on.
Just had a PM. Is it a p---s enlarging pump?
