Which GT40 to Buy?
Hello, new member here.
This seems like a very good Forum with very passionate members.
Been wanting to know which GT40 kit car is better and which ones are worst. I have seen the Southern versions with Steele Tube chassis which seem to be one of the most authentic versions from what i can tell, and of course there are the Superformance version but start at $250K. i would like to lean more towards the most authentic construction that is possible. I have seen the RCR aluminum chassis and the seem like a good choice but it doesn't looks period correct for my taste.
My other concerned is, how exact are the body's? I don't want a GT40 that "Kinda" looks like the original.
What options do I have?
Thank you in advance!!!
Randy Folsom
The ‘best’ depends more on you than the source. Before deciding you have to take into account your skill set, how much you are willing to spend, time available, etc. They range from a pile of tubes to rollers to nearly completed builds. It also depends on how ‘authentic’.
Keep in mind that these cars evolved a lot over a very short period and then were modified considerably as they were raced, often changing from race to race. They were also assembled by multiple groups such as Shelby, H&M, FAV, just to name a few. Some focused on power, others focused on weight.
Which engine will make a difference as well. It’s possible to fit a modern V8, but the original cars were designed around a 289. It’s not a linear increase in techno-wizardly, more like orders of magnitude.
Then there is what you plan to do with the car when finished. Will it be a daily driver, show, track day, or maybe a vintage racer? Will it be a tribute car or your own creation. How period correct do you want it? The more ‘correct’, the more time and money required. That’s exponential as well. The cost of a correct transaxle can be two to three times the cost of one from a Porsche.
The original cars were built like steel framed WWII aircraft, tubes were only used in the front and rear.
As to your specific questions, I can only reference my own experience with RCR. The aluminum tub is a work of art. The CNCed suspension is fully adjustable while the original cars required different upper control arms to adjust the caster. The body is molded off an original car, so it at least matches that one car, but since the originals were not perfect, the RCR bodies reflect that. The RCR is probably the best foundation for a home builder, but as you noted, it will never be as authentic as a tub built from stamped steel parts.
Finally there is cost. For an authentic car be prepared to spend much more than the initial cost of a Superformance. I am hoping to complete (they are never complete) my RCR for around $140K and it will only look authentic from 10 feet away with the clips and doors closed.
These two build logs will give you a good idea of what it takes to build an RCR.
https://www.gt40s.com/threads/chuck-and-ryans-rcr-build.22083/
Michael
Randy’s comments are spot on. The closer you get to authentic replication, the higher the cost.
Btw, steel tube “space frame” construction is least authentic, original cars were mostly stamped steel monocoque construction, although a few were aluminum monocoque.
Rob Klein
Like Michael said the closer to authentic you are the higher the cost. So how do you want to use the car and what’s your budget. Also how much of the work do you want to do and how much support do you need.
There are some really authentic chassis out there but you might need to hunt down some parts ect….
Ok guys,
RCR is out,
I posted on their FB page asking member for opinions on RCR and I received very negative feed back about RCR
Several PM's and even a phone call saying RCR is a no go.
Yesterday I put a deposit down on a GEN-Z 40 MKI, their fiberglass work looks amazing !!
Deposit was only $100, we'll see what happens once they have more info available and a confirmed time frame.
I really like the pushrod suspension on the Absolute Pace and their glass works look to be very good as I saw it on
"BUILT BY DAN" youtube channel.
I received a letter from Tornado, man they seen like a top notch choice.
As for my budget, I don't have one.
What ever it costs is what it costs.
Can I get feedback from you guys on Tornado or Absolute Pace ??
Gregg
There are many very good manufacturers of replica GT40s' out there. Probably wise to go visit some and personally inspect the cars being built and the facilities and people. Personally, I had very good luck with CAV. The stainless chassis is a work of art. I have a keen appreciation for stainless steel and good stainless welding...although SS does have it's draw backs. If you're located in a climate where it rains a lot or salt is used on the roads this could be a good option. Again, best to go see the manufacturers yourself and form your own first-hand opinion.
Ok guys,
RCR is out,
Gregg
I’m also currently looking at my options. Which builder did you end up going with?
Have not yet purchased a kit, I just finished building an airplane and we are in the Flight test phase right now. Been pretty busy. I suspect it might not even be till the end of this year.
Zenith Super Duty
Thank you in advance!!! Choosing between a turnkey GT40 and something to restore yourself really depends on your budget and patience. Personally, I went the project route and had good luck sourcing interesting candidates by checking out auction sites for insurance vehicles, where I picked up a couple of solid bases via https://www.autobidmaster.com/en/locations/usa/kentucky/insurance-vehicles/ that turned out better than expected after some wrenching. The Kentucky listings had a nice mix of American and imported models. If you're considering a similar approach, it might open up more affordable possibilities.
If authenticity is your top priority, I'd focus on the companies with a long track record rather than chasing the cheapest option. The little details in the body shape and proportions usually separate the good replicas from the average ones.
