Wilwood callipers
Hi guys im Keron and currently enjoying building chassis #74.
I just run into a small problem with the Wilwood radial callipers ,as the part # in the cataloge for the bracket doesnt fit the hub mount,so im just asking if theres any one out there thats had the same problem and that may know the correct part number or if there is one.
Problem solved modified c5 radial 6 pot front and four rear set to the c4 fronts and custom rear hub to suit bolt on rotor ,now just have to stop all the leaks..lol
