Toms method with the longer positive stop gets the contact point closer to the centerline of the piston which helps eliminate any pin offset issues, just make sure your on the fireing cycle, not overlap while doing the check, so it cannot tangle with the exhaust valve. Pin offset in most ford production pistons is around 0.060", Toms motor probably has pins on centerline.
