X/Y plywood cutting machine
Does anyone know of someone who has an x/y wood cutting machine that can be used to cut out shapes sent to them in PC format (can be CAD, AI whatever they want). Must be in Hampshire UK.
Regards
John
Mark Charlton
John,
Try your local sign shops. Most of the larger ones will have a CNC router table that will do exactly what you need. I know this because I run such an operation, (although a few km away...) and we have a table that will cut 4 ft. x 8 ft. stock up to several inches thick and within a few thou. of tolerance.
Cheers,
Need a machine that will be able to cut 2m x 1m 2mm plywood boards, but the only other issue is there will probably be about 400 boards to cut (but many of them will be a lot smaller than the 2x1m stock) - was wondering what sort of price I would be looking at to cut per board?
John,
I have two of these machines, 1 is 2 metre x 3metre machining area and the other is 1.3 metre x 1.2 metre machinig area. i would be pleased to help.
