ZF Trans Fluid Change
For $25.00 you can get a complete ZF shop manual. My ZF is in upside down so depending how yours is will change draining it. My plug is on the bottom and fill plug on the passenger side half way up.
Doc Watson
"Before draining the old oil, the vehicle should run for a short while so that any condensed water present can be mixed in the oil. The oil should be drained from a warm gearbox.
The oil drain plug is situated on the underside of the axle drive. Before screwing in the plug again, the magnet should be cleaned of adhering abrasives."
This is from the ZF-SYNCHROMA GEARBOX 5 DS-24 and ZF-Synchroma-Gearbox 5 DS-25/2.
This is for the original orientation gearbox not the flipped GT40. Also it recommends mild EP gearbox oils of viscosity class SAE80.
Morten
Mortified GT
Thanks, I need to change my ZF oils too.., just need to get the engines running and go for a spin soon.
