Hello,
Exactly what are differences between them two? The info I got so far are as follows, but still need to know the remaining (in red):
ZF
Supplied by: RBT
Manufactured by: ?
Made in: ?
Shaft centres: 79mm
Crown wheel diameter: ?
Bevel or Hypoid: ?
Hypoid offset: ?
Shift forks on input or pinion shaft: ?
Direct shifting mechanism (shift finger a la Hewland), yes or no: ?
Dog-leg 1st gear: Yes
Reliability issues: ?
Recommended max. engine torque: ?
Are non-syncromesh gears available: ?
Clutch fork or concentric slave cylinder: ?
Weight: 70kg
Price: ?
ZFQ
Supplied by: Quaife
Manufactured by: Quaife
Made in: England
Shaft centres: 85mm (same as G50, so can Porsche gears be used?)
Bevel or Hypoid: Hypoid
Hypoid offset: ?
Are non-syncromesh gears available: Porsche Cup?
Weight: 65kg
Price: ?
ZF
Supplied by: RBT
Manufactured by: ?
Made in: ?
Shaft centres: 79mm
Bevel or Hypoid: ?
Hypoid offset: ?
Weight: 70kg
Price: ?
ZFQ
Supplied by: Quaife
Made in: England
Hypoid offset: ?
Weight: 65kg
Price: ?
