Hi all
I thought I start a post as I need to wrap my radiator pipes that pass through the cabin of the car. The aim is to reduce as much radiant heat as possible so what is the most ideal material/wrap etc to use.
I initially bought some self adhesive aluminium insulating pipe wrap but I am not sure this will be the easiest stuff to apply and remove should I need to remove the pipes.
I've also been looking at exhaust pipe wrap and fireflex Silicone jacketed fiberglass sleeving which both look easier to fit. However I am not sure how much radiant heat the fireflex sleeving would prevent.
If you guys could suggest the best options that would be great
