GTD air conditioning (AC) functioning
Hello,
can someone of you explain to me how to use the air conditioning in a gtd replica.
I mean when you are in the car which button do you touch to switch it on and have fresh air coming.
Thank you by advance for any return. Franck
Here it is. In the middle of the dashboard I have one adjustment wheel having 3 positions for the "speed", the one on the right for the heat "intensity". On the bottom left of the dashboard (not visible on that picture) there is a two-position pul/push "tab". Is it the one to open or close for AC ?
Malcolm
ok thanks. that is not the standard GTD AC switch gear. it looks improved! however i suspect it is all you have. the push pull lever on the dash leg is a water open close valve to send hot water to the heater matrix not to do with AC running. hope that helps narrow down your issue.
