I'm having a very strange problem with my AC (standard Vintage Air slimline unit that comes with the SLC kit). The AC works fine -- even puts up a valiant fight in TX weather. When I'm driving, however, the unit leaks water (condensate) into the passenger compartment. Quite a bit. When I'm stopped, it drains just fine through the drain line which I have routed to a hole in the floor of the monocoque on the right side of the passenger footwell. I've checked for leaks / blockages and the only thing I can think of is that the airflow under the car when moving is creating pressure preventing water from draining, but I'm really grasping at straws on this one. I literally have to put a bath towel down in the passenger footwell and it's soaked after an hour or two of driving since it's so freaking humid in Austin this time of year!
Does anyone else have problems with their AC condensate draining? How do you all have your drain hoses routed?
