RCR GT40 Cinderella in France
Hello Bart, unfortunately, I cannot read any designation on it. It is full of cable or pipes around it,and I do not see any tag. I can only tells you that it is piloted by the Accle DFI system and see the photo, if it may help you
Hi Jean-Marc,
I am looking for the smallest distributor for my 289.
That is why I asked, but whiteout a number I am clueless.
Thank you for taking the picture
I come back to keep you updated ; I ama seeing the end of the tunnel. I finsihed to put in place the windows and front light glasses. I was unable to renew the surfaces of the ones that I received with the car. They had scratches and even after repolishing with very fine grain and using various type of product the result was never acceptable. Finally I order part from Tornado, The thickness is much less than the ones coming from RCR and they seems to be very sensitive to scratches.
Now I am working on the oil circuit, I am waiting some parts to equiped the engine with a oil radiator and an Accusump. The Accusump and its valve are in place.
I modified also the seat to allow an easy deassembling of the back and give a quick access to the engine bay, and to be compatible with a 6 point harness.
Engine is running, at this time in the garage, I had a hard time to put the good parameters on the Access DFI7 injection, but with a little help from the creator of this device George Landis, I finally get to it. Now I should go a spped shop that has a roller bench to optimize the adjustment.
My last problem a t this time is the height adjustment. To I tried to adjust the front to 110mm, 4.3" but when I am doing this the spring is not fully compress if I lift the front on a jack and I wunder what would happen on a track if the suspension is completely decompressed like it is on a jack.
The ressort is not compressed anymore if I reach a height of 160mm 6.3". Is there a problem some where, should I put a spacer, or change the spring length? Any idea ?
Sorry Mark I miss the meaning "you are leaving the 8 stack" ? I am french, could you clarify ?
Hi Jean, in the States the fuel intake system you have on your engine is typically called an 8 stack for the 8 individual carb or injectors. Usually Borla on Inglese brands or a few others. I have an RCR on order but wont be getting it until late next spring early summer.
Ok Mark, yes its a 8 stack Brola first generation, it the reason why it was equiped with Accel electronic that no more exist because purchased and replaced by Holley
Jerry, thank you so a spacer is required.
nice that your ECU's are in the position of the passenger seat! I'm not looking forward to trouble-shooting mine - they are located behind the passenger seat and the fire wall /-:
Randy Folsom
View attachment 149950View attachment 149951
View attachment 149955View attachment 149956
For your coil overs. Drill holes in the hats and secure the hats to the springs with zip ties. This guidance comes from the Factory Five Racing Roadster (Cobra) build manual. On the FFR forums some builders recommend using Stainless Steel zip ties.
Thank you Randy, it is a good idea, but a friend, engineer on Michelin tires for Le Mans racing car told me that they use "helper spring" on racing car especially to keep the spring in place when you lift the car on a jack. It also what Jerry suggest. The spring have almost no impact on the stifeness of the main spring and is very small when it compress. On top of it is rellatively cheap.
Helper springs are in place. It was necessary to cut the centering ring that goes between the regular spring and the helper spring to allow the complete compression of the helper spring in compress position.
Now I am finishing the oil circuit, Accusump + radiator but some fittings were missing and I should finish it next week. I order my fitting to Torques UK, for me an excellent vendor.
In the meantime, assembly of the rear tow ring; I had to attach it to the main chassis because the rear subframe is only there to support the rear hood and didn’t seem rigid enough to be a good towing point.
To continue to work I tried to adjust the suspension. Not an easy task. I adjusted the height first about 4 inch front and 5 inch back.
After a lot of other little details, I started trying to get close to the suspension settings. By searching on forum, I made a choice that I will try to approximate before putting it on a test bench or on a track.
Front per side
Toe +0,07° = 0,5mm on 414mm wheel
Camber -0,8°
Caster +5,0°
Arrière par roue
Toe +0,1° = 0,7mm
Camber -0,8°
Caster +6,0°
Some oddities, the toe values are very low, almost zero. Another thing, a caster value for the rear – I think this refers to the spindle inclination angle since, obviously, the rear axle is not steerable.
I adjusted the front, except for the caster which I haven't done yet, and I'm almost at the correct values. A bit annoying because you have to remove the upper ball joint each time to adjust the camber. But after 3 removals, I'm at the correct value.
For the hunt, it will be worse; it seems to me that I will need to get it by adjusting the lengths of the two ball joints on the upper arm. So I’ve put it on hold for now, knowing that it’s not easy and I need to dig deeper. If I understood correctly, I need to measure the inclination angle of the front suspension before and after rotating the steering knuckle by 20°.
So I started on the rear suspension; that’s more complicated. I’ve made a basic schematic, see PDF
The camber is practically at the correct value, and I should be able to adjust it with the C link. My problem is the toe; it is far from the correct value, and I tried to fix it with the D and E links (tie rods), but both are at their limit, and moreover, they are supposed to be used for adjusting the caster. So in my opinion, only the two ball joints, A and B, remain, which should allow me to adjust the toe.
What’s your opinion?
My .02 worth having built an RCR40 ::
Clearance for The upper rear control arm you identify as “C” is a key reason to get the rear (correctly stated) inclination angle moved toward what would normally be thought of as positive castor. Also in consideration is achieving the 95” wheelbase and/or centering the wheels within the arches..
I just mount my new tires. The Avon historic CR6ZZ delivered with the car were 12 years old and completely dry, even if they never saw a race track.
After a lot of considerations I bought Nankang historic CRV6 from Nakang Nederland in exactly the same dimensions than the Avon. My total cost was 2000€, 400€ less than the Avon for 215/60x15 front and 295/50x15 back, that guide my decision.
For the back no problem but for the front they are a little bit higher in diameter, about 1/4".
The result is when I turn the front wheel they are coming very close to the lower side of the body. Anyway I have to reajust precisely the height. But I will may be try to move the upper triangle forward. I do not have a lot of adjustment only one washer left. If it remain to close, I will have to cut in the glassfiber of the bottom sides.
What do you think ?
If you have problems in the straight position of the wheels (photos) how do you envision turning them under steering? A while ago I test-fitted 225/60 Avons which I use on another car - I had the same problem as you and went back to my 215/60R15. I think the only choice is to move the front suspension forward as much as necessary. On my RCR the front wheel sits slightly to the rear of the wheel arch so this would be feasible.
