Type of battery
What is the best type of battery for a SB302. 380HP. MSD/Webers ?
I have actually a 12V 72Ah 680A VARTA type but when engine is hot, it doesn't not always start the engine.
Many thanks
Grtz
Fred
I use this one on my SB347 with fuel injection runnIng a Holley TERMINATOR.
No problems so far.....fingers crossed
Jerry
Jerry
Jerry, I cannot found the Ah rating, do you know it ?
To much initial advance.
Old skool tuners trick, how much can you run.... till it won't crank when hot. Just back off 2 degrees.
Does Lithium batteries require a special connction to the alternator, or standard electrical circuit is going well ?
Lithium batteries cannot be charged as though they were common Lead-Acid or AGM batteries. There are Lithium batteries out there that have an internal Battery Management System (BMS) and those would require no additional equipment and could be installed in place of a LA or AGM battery.
Bill Kearley
Fred, this thread went of track. Please use a led acid of some sort. Have you checked your cable size and connections, load tested your battery and checked the starter current draw ??
I use a big lead-acid battery, but I have a "total loss" system- no alternator. But then again, we only run full blast for 5 miles.
