A/C compressor
Starting the wiring on the SL-C and have a question on the a/c compressor. The ISIS manual indicates that the tan wire goes to the a/c compressor. The a/c compressor only has one wire (black). The kit also comes with a a/c ground wire. Do I just connect the tan (iSIS wire) to the black a/c compressor and not use the ground since the compressor is already grounded to the engine?
Please advise. Thanks
Yes, the ISIS tan wire sends 12vdc to the AC compressor to actuate the clutch.
The compressor only has 1 black wire with a bayonet style connector. That's for the clutch.
You do not need the ground wire for the compressor, just the tan from the rear power cell.
