I have never seen this info posted so I thought I would put a feeler out for it. On the lower A-frames, where there are rod ends that attach to the uprights(DRBs and others), how far out should the rod end be placed in order to get proper alignment. I realize the short answer is none, but for proper alignment and safety, how much can the rod end be let out. This of course puts the weight on the threads which can't be good, even when using bolts on both sides of the mounting. Especially if you change tires to a different size(width). I understand this is influenced by the "proper look" of the tire to wheel arch. I guess I am also asking what is the inner measurement for tire to tire on the rear. What influence are there for the proper placement of the uprights. Being a non engineer I have no clue about these things, and a good explanation with pros, cons and considerations would serve all on the forum. How does placement affect handling and such?? As a non engineer I'm not sure exactly what to ask. How does wheel size(width) to tire width work into this? I understand a little about offsets/centerlines and the like. I realize this is a lot to talk about, but I can't remember any discussions on it. Very soon I want to take my car to one of the race shops to get all this setup and sorted before getting it turned loose on the road. I have the articles on alignment in the home shop and they have helped me get things aligned enough to get the car to roll around without the tires squealing on the garage floor. Any and all info would be appreciated.
