I need a little help in my final hours. I have two different specs for the toe alignment. One shows a "street" setting of front: out (neg.) 3mm or .120 total, Rear: shows the same. The other spec only shows it as 15 minutes, no neg. or pos. First question which won do I use. Also I thought you used toe out on race settings and not for the street. If I should use the 15 minutes how do I measure minutes, I'm sure it not with my watch, and is it positive or negative? I would really like to drive my car today so a little guidance would be greatly appreciated.
