Hi all.
It's been a while since the last update but I've done plenty on the car.
I spent Christmas designing and making the wiring loom. Not too bad a job as I did most of it in front of the telly watching christmas films and drinking beer.
I've made a fuse and relay panel that fits nicely up out of the way next to the steering column, and fitted all the clocks and switches, and wired up the dash. The dash will probably just get a coat of black satin paint before the car goes for IVA, then i'll decide how I want to finish it.
View attachment 69825View attachment 69831View attachment 69830View attachment 69829
Also fiberglassed some brackets to the dash to make fitting and removal easier.
View attachment 69828View attachment 69827
Made some panels to seal off the fuel filler hose from the inside of the car.
Heater hoses and radiator hoses fitted.
The radiator hoses have been wrapped in felt insulation, then covered in alloy foil tape. They will get insulated again before the centre cover goes over the top. The gear shifter is also in. It's pretty tight in this area so I made a panel that keeps the hoses and wiring out of the way below the shifter.
View attachment 69823View attachment 69822
Heat/aircon unit fitted, fans and radiator mounted, and also the front anti roll bar.
View attachment 69820View attachment 69821View attachment 69826
Not too far off finishing the interior wiring and pipework then I can start the upholstery side of things. Hoping to get the chassis sat on some wheels by summer, with an engine in by the end of the year.
