OK, it's not strictly GT40 related, but I thought it better to post here than a GT40 related technical section. I have a TR6 fitted with a rover V8
I took the gearbox off today to replace the thrust bearing and I have a problem getting it back.
The TR6 gearbox is attached to an adaptor plate which in turn is attached to the engine. I removed the gearbox, leaving the adaptor plate still fitted to the engine (the box comes out from inside the car) and I noticed that the adaptor plate bolts were loose. being as how the adaptor plate would usually be fitted to a stag, this isn't usually a big problem as you just fit the plate to the gearbox and bolt it to the engine. However, in a TR6, space is TIGHT! I did manage to remove the adaptor plate from the engine and just about wiggle it out of the hole, but there is NO WAY the gearbox+adaptor plate will go anywhere near the aperture when bolted together.
I am going to have to take the adaptor plate off the gearbox and bolt it back to the engine. This leaves me with a problem. As the bolts are just "hanging loose" from the adaptor plate, if I try and offer up the gearbox, it will probably just push some or all of the bolts through the adaptor plate and into the flywheel/clutch area.
What I need is a way of fixing these steel bolts (at least temporarily) in the adaptor plate so I can bolt up the gearbox. Once the box is in place the nuts can be tightened and the bolt heads don't seem to revolve, it's just getting it mated in the first place.
I've thought of aralditing them in place, but I guess one whack with a 100lb gearbox would possibly push them straight back out.
There are 9 bolts alltogether and the ali is too thin to drill and tap
Any advice or tips greatly appreciated.
Simon
Simon
