Somewhere on this computer is a simple program to calculate the "stiffness" of a bar so you can work out what you have been using and what you need to replace it with to get the same or stiffer bar. I will post it when I find it!
Have you found it?
I want to go ahead and get some bars ordered up, but, not sure where to start on "stiffness". Any RCR owners out there with roll bars that have an idea of rate that is added by use of the bar? If so, what sort of design did you use and what company?
The front the bar can tie into the cage mounting plates that go through the chassis and are backed by a plate of the same size. The attachement points should be plenty strong. But, I think the rear bar will be a bear to make as there seems to be no left to right crossing at the rear that is entirely straight, or, even close to straight. I'll have to look at that a bit.
