Hello together.
Im searching a bearing to fit my ZFQ to the roush 427 IR with mcleod clutch.Where can i get this bearing (s).Has someone the same configuration?
Thank you for answering.
greetings from CH Urs
If you are talking about the throw out bearing, it is from a Pantera, you can also use a Mcleod hydraulic T/O bearing.
For the pilot bearing then you can use a needle bearing set up from a 5.0 Mustang.
Dave
