George, it's like the computer "Deep Thought" in "The Hitchhiker's Guide to the Galaxy" -To understand the answer you really need to understand the question. 42 doesn't mean much without understanding what was asked. If you haven't read it then you have some extra homework.
Getting the concept of torque and power does not require you to be an engineer but it is absolutely necessary if you want to make an informed decision on the question you are asking. Without that understanding all you are asking for is someone else's "recipe" and opinion and those will be many and varied.
As simple as I can make it - force acts on a piston, it is converted to twisting force (torque) by the bottom end of the engine, this twisting force can do work but how much depends on how fast it is spinning. More revs with the same torque means more work. That work is called power.
More torque with the same revs also means more work.
Two shafts, one with x torque and 2y revs and the other with 2x torque and y
revs:
If you lift a weight with the power from those setups without gearing then one will lift a lighter weight faster than the other, but geared correctly both setups will lift the same weight the same distance at the same "speed". Ie they have both done the same amount of work - same power. Hope that makes things
clearer.
There are some other things to consider, eg friction, but you must grasp the basic concept first.
Once that is understood then the importance of things like the shape of the
torque curve will become clearer. An engine has to suit the car and purpose for which it is built. Understanding another persons desires is far more difficult than understanding basic physics.
Chapman and Shelby, yeah I guess it is an unfair comparison... Best not to
explain further methinks. Sleeping dogs and all that.
Davinci's aircraft designs looked a bit dangerous but he was still a genius. I don't remember the other guys name or what he did unfortunately...
Or maybe this old historic story I just made up might illustrate it. Two guys stand by a river trying to get a message to the other side, they both roll it up and throw it. Later on the river gets a bit wider and they have to get a message across again, this time throwing doesn't quite get the message across. One guy folds the message into a paper plane and it flies across the river, the other guy rolls it up and gets a bigger guy to throw it harder. Eventually they get to a wider part of the river again and the plane flies across easily but no matter how strong the other guy is, he just can't throw the message across the river. BTW the second guy, Rod, was pretty keen on his image and looked pretty good so he was called 'Hot Rod'.
These days in that country you are free to make a paper airplane but if you want to get a bigger guy to throw a paper ball for you then you might strike a few legal issues.
I wonder if this story got the message across... ;p
Hardy, you and I can sit up the back with the other cool kids.
Tim.
