For those that opted to use a hydraulic throw out bearing with their ZF, where did you route the top bleed line through? Did you drill a hole in the bellhousing or trans case above where the shift linkage would normally be? The bottom line can obviously run through the shift linkage hole but any help on the bleed line would be appreciated.
