Ken Roberts
I need to order the correct banjo fittings for the brembo calipers for my SLC. I know they are 10mm by 3AN but should I be buying straight, 90 degree or 45 degree fittings? Please post some pictures of how you ran the hoses.
Here are the GM part numbers for the Banjo bolts and crush washers needed to attach the banjo fittings into the Brembo calipers.
bolt.........#11569590 (old number #11570052) (4 required)
washer.....#21012386 (8 required)
Please also mention what fittings were used at the other end of the flex hoses.
