Cockpit Cooling Solved!
Ian Clark
It took a lot of R&D to come up with this, should also improve contact patch:) The car is Angelos' (Frknfast) Gulf Spec. CAV GT40, FRPP 392 Crate, 48IDA Webers, ZF 5speed.
Would that be RW BTU's/ Hour or flywheel BTU's/ hour ? And what type of wood do you burn? High fiber maple or hard redwood? Hummmmm Maybe a blend of redwood and blasa. redwood for the high BTU content and balsa for weigh savings.
Ian Clark
Hi Tony, Howard
Its actually a compressor fan for a gold mine. The shop next door rebuilds them. If you think the fan is big, you should have seen the crane that moved it!
