Doc Watson
I need to order the metal for the base of my cold air box. Im using aluminium for the base plate and was thinking of using 2.0 mm sheet. The sides of the box will be held in place by small screws (see the detail on the racing icons site) will this be thick enough to hold a screw in place?? or should I use bolts and nuts to hold on the sides of the box?
I'm thinking the plate needs to be at least 2mm thick as there will be 2 plumbers blocks attached to the base plate which will hold the throttle linkages.
Any thoughts?
Andy
Any thoughts?
Andy
