Crank angles
Glenn M
Does anyone know what the crank angle at BDC on the intake stroke is on a Ford 302? It is 540 degrees for a SB Chevy (sorry about the language!) and it would be easy to assume that it is the same, but we all know what assuming does!
Thanks guys
Glenn M
Thanks Jac.
Are they the same then? I thought it was 1-8-4-3-6-5-7-2 for the Chevy and 1-5-4-2-6-3-7-8 for the 302? Although, just to confuse myself further, I should say mine actually has a 351 firing order so it's 1-3-7-2-6-5-4-8. :confused:
All the same even 13726548 is , just flipped from end to end. The numbers mean nothing other than allowing humans to figure it out.
On any 4 stroke BDC Intake open is always 540° after TDC firing.
