Electric Water Pump How to.
Ian Clark
Mid engine cars are just more complicated compared to front engine/rear drive or rear engine rear/drive. Even the OEMs have challenges with engine compartment heat, reduced lifespan of soft parts in the engine compartment, plumbing, cooling, wiring, a/c and tool access for routine maintenance.
If you are prepared to do the best you can with the information available (especially GT40s.com) AND prepared to potentially take it apart because of an unforeseen packaging issue or systems malfunctioning, you are on the way to building an exceptional car.
Regarding the ability to heat the cockpit, there's no shortage of hot water in a GT40 replica or original.
Most of the conventional wisdom about heater function in hand built cars comes from the likes of hot rods, restomods and sports cars based on front engine front radiator layouts. Not much help there, just pay attention the height of your header tank and bubble bleed lines.
In GT40 applications you have several options based on your chassis manufacture provisions and your choice of drivetrains for routing coolant pipes between the engine, radiator and heater.
Although "individual circumstances may vary", the simple mechanical waterpump with thermostat, bypass plumbing, adequate rad fans and proper fan controller combination should give no trouble cooling the engine or heating the cockpit. Although the accessory drive is more complex and space to the firewall almost non existent.
Back to the topic of this thread:
The use of a remote mounted electric water pump reduces accessory drive complexity and provides more space to the firewall. The electric water pump on/off/variable speed and radiator fan(s) on/off/speed have to be managed by the ECU or other controllers. A mechanical thermostat is redundant in this setup.
With proper control of the water pump and rad fans to engine will warm up quite quickly if the car is happy to idle for a few minutes. Then you have hot water available...
The tight packaging of the engine compartment, under dash area and plumbing routes will narrow your choices as to where to run the heater hoses. The direction of flow however is always the same: from the engine to the heater to the radiator inlet. It's preferable to mount the heater shutoff or variable flow valve outside the cockpit, reducing the number of really hot water leaks.
The system itself is not difficult, it's the packaging layout and leaving yourself access for future maintenance that's the challenge.
Pat
I wanted to jump in and see what people are doing to route coolant hoses from the block. I have a Dart 302 block and have an WP adapter plate with 12AN male outlets. Should I run long sweep 12 AN 90s? Is this large enough to go to the EWP (using the recommended Pierburg). I’m trying to figure out fittings and hoses for whole system while everything is out of car in floor.
Attached picture has straight 12AN-12AN for now.
I have a ford 351 and a Davies Craig electric water pump with the adaptor plate rather than mechanical pump. Where should I connect the T stat bypass too? Should it be plugged?
Bill Kearley
Take water from right behind the thermostat on the intake and run a line to the intake side of your pump. Up load a pic of the pump your using, there site has a few different ones !
Wiring question:
The Davies pump uses ground to activate the fan relay. This uses pin 85. They suggest jumping pin 86 to 30. Which brings 12 volts thru pin 86
The problem I’m having is the diagram for the vintage air wiring uses 12 v thru pin 85 and I think ground is 86 via the trinary switch.
How should this be wired? Should a second relay be used and run them in parallel?
Randy Folsom
I have been trying to figure out the EWP coolant system electrical setup. Below is my first attempt. I am not any sort of wiring wizard so there are bound to be issues or concerns.
I am using the Pierburg CWA 400, the TinyCWA controller from Techmotive and a relay with up to a 10 minute delay to keep the system running after the car is turned off.
The fans will be turned on and off by the TinyCWA controller, but when on the highway, I would like to override the controller and turn the fans off since there should be plenty of air coming through the radiator.
My thinking is to put a thermo switch at the output of the radiator that will cut power to the fans when the coolant is cooled sufficiently. I don’t know what that temperature is.
Ian Clark
Hi Randy,
Have you checked in the instructions for hi/low temperatures settings for the fans? If so (most likely it does) then you have no need for a fan off over ride switch.
Randy Folsom
Hi Randy,
Ian,
Thx much. I am new to EWPs and rear engine cars with the radiator up front so please bear with me. I don’t know where the high/low temp reading is coming from that you referenced. I am guessing a temp sender in the intake manifold. If so, then I assume the fans will run when the engine is hot regardless of how much cooling is done by ambient air at the radiator. If there is a temp sender on the radiator, I am guessing it is located in one of the radiator’s side tanks. That water should also still be hot. My thinking is to place the sender on the output since this should be after the water has been cooled by the radiator.
My advice would be to put all the temp sensors in the intake manifold. The coolant temp target is the coolant temp at the hottest location in the complete system. That's the top of the engine, heads, and by extension, the intake manifold.
The fan on temp would be selected to be about 10F above the system target nominal temp. So if you wanted the coolant in the heads to be 185F, for example, then turn on the fans at 195F and have them go off at 175F. This way at normal running speeds airflow will keep the coolant at the target temp (185F) and the fans will not come on.
I would like to see an override switch so that the fans can be manually turned on at the drivers discretion. Lots of good reasons for this. I also think it would be best to split the protections between the two main loads, The fans and the pump, separate the circuit breakers of each, Power the controller of the pump from the pump circuit breakers, and the fans from the fan circuit breaker. Place your override fan switch in the fan relay control circuit.
I'll read up on the tiny controller a bit and see if I can draw you a circuit diagram for the whole system.
Ian Clark
Hi Randy,
The Hi\Low temperature setting is a function of the Tiny Waterpump Controller and responds to the temperature input from your sensor(s) on the engine, radiator.
Additionally the A/C pump relay can to trigger your rad fan relay. It does help the cooling system to stay ahead of engine temperatures due to low air flow through the radiator, much like an override switch would do if you were stuck in traffic with A/C on.
On re reading my reply above, and in agreement with Howard, a manual override is required. Modern production cars don't have one but the original GT40s did.
I left out the run on controller. If you have a manufacturer document on it I can look it that and include it if you like and it will work. Frankly, I don't think you need it. Just let the car cool down a bit before you turn it off.
Randy Folsom
I updated my Cooling System Circuit diagram before I saw John Howard’s drawing so will likely update it again.
I added the A/C Trinary switch, pump and fan indicator lights, manual override, and radiator outlet temp switch with a potentiometer. The Tiny CWA has to go to Pin 85, while the delay relay and manual override go to Pin 86, so needed to add another relay.
The primary temp sensor is the one on the manifold connected to the TinyCWA controller
The overrides that force the fan on are the A/C Trinary switch and the manual override switch.
My hope is that the radiator outlet switch will only cut off the fan when the A/C is not running and the coolant temp coming out of the radiator is low enough to not need the fan, i.e., driving on the highway on a cool day. I will likely move the radiator outlet temp sensor as described by John Howard.
For sure John Howard’s diagram is easier to follow :)
Randy Folsom
Wiring question:
The Davies pump uses ground to activate the fan relay. This uses pin 85. They suggest jumping pin 86 to 30. Which brings 12 volts thru pin 86 View attachment 144407
The problem I’m having is the diagram for the vintage air wiring uses 12 v thru pin 85 and I think ground is 86 via the trinary switch. View attachment 144408
Not an expert, but my understanding is it doesn't matter if 85 or 86 is grounded. Likewise 30 and 87 are interchangeable. Convention is grounding 85. Some signal inputs are positive voltage so if you're trying to stay with the conventional pin 85 input, then 86 is ground, but you can just as easily connect your positive input to pin 86 and use 85 as ground. Not sure what to recommend, but I suspect there are standards to make future trouble shooting possible.
Question.
You are driving down the highway on a warm day.
You have airconn on
Will your fans be running?
If so why as surely natural airflow is doing the work and no fan is necessary.
I can only see the fan not running if there is a road speed sensor that stops the fan above say 25 mph
I never had this problem as never ran aircon
Randy Folsom
Another attempt. I used John Howard’s drawing as a starting point. This one is a bit less complex. I have not figured out how to turn on the water pump without going through the controller. I think need to apply 12v to the grey/red and ground to the grey/black wires on the pump. I am going send an email to Technomotive. I also did away with the idea of a separate circuit/temp sender to turn off the fans. I think it best to rely on the controller. I still need to add the status indicator lights.
Tecomotive are now saying this -
Attention!
Since around March 2024, the CWA400 only supports control via LIN bus.
Pierburg is now installing new internal electronics, which can no longer be controlled via PWM.
For the time being this pump is therefore no longer compatible with our tinyCWA!
We are currently working on a variety of solutions for this.
However, the simple on/off mode of that pump still works.
To use it without a controller, you must connect it as follows:
Pin 1: 12V / Pin 2: GND / Pin 3: 12V / Pin 4: GND
Tecomotive CWA400 Link
Has anyone managed to confirm or deny if it is possible to control the newer CWA400 with LIN bus by using the Davies Craig controller?
Paul Proefrock
Lee,
Pierburg makes two different style CWA400's. The PWM version is the older style body where the outlet is not clickable. It is available online.
They also make a newer body style with the same CWA400 identifier. The body is manufactured differently and it is only available in the LIN version.
Sorry, no input on the use of the Davies Craig controller
Thanks Paul. Before you mentioned the newer PWM CWA400 pump, I dropped a line to Tecomotive -
Hi. I am very keen to buy CWA400 pump, but I see your TinyCWA no longer supports. I already have Davies Craig Pump/Fan Controller. Can the DC controller control the new LIN pump? Thanks.
Hello Lee,
No unfortunately not.
As you said. The Davies Craig controller is a normal DC motor controller.
As in .. PWM the pumps power supply ..
That does not work with any of the CWA pumps.
We thought we had a solution with the new PWM CWA400 pumps from Pierburg.
But there are problems with those, too. (only half of them actually
react to the PWM signal .. Pierburg is investigating)
That forces our hand a little. Right now we are experimenting with the
LIN control.
Maybe we can hammer out at least one solution in a few weeks.
We are unsure at the moment. We need to do more testing first.
Kind Regards,
Tobias
Tecomotive
Paul Proefrock
I am at the point on my build where it's time to figure all this out. I've once again read the thread (Thanks, Howard) and have it all figured out except the thermostat. Being in the Midwest, we need compartment heat, so I plan to run a heating system. I like Randy's approach (Post #63) with the BMW remote thermostat.
Two questions about a system like that.
1) Do the tee's for the heater takeoff and return only have to be in the direction of the flow or does the heater tube takeoff stick into the main line some amount to create turbulence and flow? ie, is the main run smooth or does the tap stick into it some amount?
2) The BMW thermostat is 1.30" diameter inlet and outlet. That will take a little finessing to adapt to the 1-1/2" hoses run for the RCR coolant lines. Is there another model thermostat that someone has used that matches the 1-1/2" lines or maybe one that someone else has used?
Again, Howard, thanks for your help on this. Time to go to the shop and start running some lines
Paul
