ErikK's Valkyrie rebuild
Here are some photos of the FiberFab Valkyrie I just purchased. Yes I know it's not a close replica of a GT40 but it is certainly inspired by the GT40. As am I. :)
Some details:
2" x 5" rectangular tube frame, not a VW floorpan. So it's clearly a Valkyrie not an Avenger.
Chevy small block, I'm told it is a 305. Appears stock, with iron manifolds, Quadrajet, and HEI distributor.
Corvair rear suspension, Corvair transaxle with Fiberfab adapters (similar to Crown?)
Production looking front suspension, I'm guessing Corvair since the drum brakes :-( look the same as the rear. But it has rack and pinion steering.
I'm told the previous owner parked it in a barn in Michigan before he died. I bought it from his widow and her family friend. "Ran when parked" is good news in this case, it's a complete car not an incomplete kit. The body is in remarkably good shape and the frame is rust free. But it has not run in 16 years.
Progress and status:
- It steers and rolls.
- The engine cranks over on the starter motor, it is not seized.
- I drained the gas and coolant, there were only a few ounces of each, the coolant was green which is reassuring.
- Removed carburetor to rebuild it.
- Brake and clutch pedals have at least some feel. Next step is to flush and bleed the hydraulic systems. I have a pressure bleeder and the bleeder screws that I have tried so far were not too stuck, so this should not be hard.
- Next up rebuild the carb and put in fresh gas, see if it will start. If I can drive it even around the parking lot that will give me a lot of reassurance and enthusiasm to continue the project.
- Working on clearing indoor storage room for it in my shop.
Questions and thoughts:
The things I like least about the car so far are the side window situation, followed closely by the difficulty of getting in and out of the cabin.
The drivers side window is plastic, looks home-made. The crank regulator does not work but I can push the window up and down and it more or less stays put. The passenger side window is missing. The rollers in the door and the regulator crank are there so it may once have existed.
As you can see it has no vent windows, does this make it a 'long door' car? But look at those fixed black panels behind the windows, I think a previous owner added them to go with the homemade windows. They make ingress and egress even more difficult. I'd sure like to find a window solution that lets me eliminate these. Any suggestions?
I can imagine a long list of things I'd change on the car, from minor to major. But I'm not going to start into those before I get it running and driving.
I’m pretty sure that the rear glass is from a 65-66 Ford Mustang Fastback. Perhaps some of the other glass was similarly sourced?
The plastic side window is gently but definitely curved. Flat would be a lot easier.
I have read that the vent window is 60-something Mustang and the accompanying side glass is 60-something LTD hardtop rear door glass. I dunno how hard that would be to find.... And I don't know what the one piece glass (without vent window) is from.
It was my first kit car when i was 18 , many configurations, 3 paint schemes. I had a corvette motor and always had heat problems, motor wise and cabin and broken transaxle parts. Last iteration before i sold it , cut open the roof and put a Turbo 350 trans. Depending on your skill set and equipment best to strip it down and start over, the build looks very sketchy ! ! There's still a website Fiberfab that has some original build manual's , parts needed documentation , sparse to say the least. I used the modified Mustang vent window, 66 LTD front window and VW track with electric motors , very labor intensive to make it all work. Learned a lot along the journey, you will too.
Well yes and no. Maybe compared to a serious GT40 replica the build is amateurish. But for what it is, a 1970's fiberglass kit car built by a home builder (I assume) it's really quite good. I haven't seen anything grossly unsafe or that made me wince more than a little. Lots of things I would like to change, but nothing awful.
My eye for this is pretty good. I'm an engineer and I've led several prototype and low volume vehicle projects. I've been turning wrenches since the 1970's and I'm a licensed mechanic. But I've never owned a kit car or a Chevy engine before so I'm new to this one.
My plan is first of all to get it running. Drive it enough, even if just around the cul-de-sac, to build a little momentum on the project. Then at least remove those door restrictor plates so I can hopefully get in and out of it in less than 3 minutes and without dragging my knees and my butt and both hands in the mud. Then drive it enough so I can see if I fall in love with it or not. If I don't, I'll find it a new home with somebody smaller or more flexible who will love it. And if I do fall in love with it, then I'll start on the list of modifications. Hopefully one at a time so I can keep driving it occasionally and keep the momentum up. I don't want it to become another stalled project.
Not directly working on the car, but progress on the project.
With some helpers, yesterday I assembled this four post lift, and today got the Lotus out of the way and the Valkyrie parked indoors where it will be safe from the snow and easier to work on. This is the view from my desk, hopefully it will inspire me. The Valkyrie is up on casters to make it easier to roll around, that's why it looks so tall.
Thanks Brian! I have seen that site. Sadly it's pretty much a cobweb site, hasn't been updated in years, maybe since 2006. Yes it does have some good info, the old assembly instructions etc. I wonder what ever happened to FiberFab and the people involved? I'd love to learn more about the history of the cars. There is a FB group and some info on the web, I've been poking around.
Brian Kissel
Best I can do Erik. I don’t do any social media, so have no idea what’s out there. Just stumbled across that site. Seems like I have a original article from Popular Science or Popular Mechanics from back in the day. I’ll look around.
Regards Brian
Progress report and a major milestone:
First the exciting news: It runs! ! !
After rebuilding the carburetor and hanging a temporary gas tank, the engine started right up. It shows good oil pressure. This makes me feel much better about all the long hours this project will require.
- one piece side windows ordered from Mark Clapp. This will let me delete the plates that block part of the upper door opening, thus making the car a bit easier to get in and out of.
- flushed and pressure bled the brakes, now it has reasonable pedal feel.
Erik K,
I am thrilled to see your post! I have been infatuated with GT 40s my whole life. I too am a mechanical engineer. I have done a good bit of car restorations primarily 440 mopars and some minor racing. I acquired a VW or corvair powered Avenger not done and in parts recently. Then I came across a "new" 2004 vintage Valkyrie body and frame I could not pass up. I plan to build my Factory 5 cobra kit next and then in a year or so jump on my Valkyrie project after I retire formally. Plan to go 302/347 small block Ford (like in my Cobra) and probably Porsche Boxter S transaxle and Corvette C5 rear suspension. I would love to hear back and see how you are coming. This my first post on the site. I would love to hear from other Valkyrie guys too...we certainly are the minority.
Thanks Michael
Erik K,
Thanks Michael
Wow, a clean and un-molested Valkyrie frame and body, that is a find indeed!
Small block Ford and Porsche transaxle is solid choice. This is much shorter than the Corvair transaxle that the car was designed for, so the engine will sit farther back and you could use that to make more room in the cockpit. I have no experience with Corvette rear suspension but it seems to be popular.
There are Valkyrie resources on the web, there are I think three relevant forums on that Face thingy. ;) And the original build manuals are still available, I think there is a link in a post above.
I've been making progress on my project, a test drive is so close I can taste it. Compared to building a new car my task is much simpler, there is much less to do. And also sometimes more frustrating or unpredictable, as I find messes the previous owners have left. So far in general the car has been easier to work on than I expected, I'm enjoying it.
Attached is the VW/Corvair based Avenger I acquired that is now on the "back-back" burner since I acquired by 302 based Valkyrie body and frame. Also attached is the first Cobra my car buddy and I built less body mounted...
