I had planned on adding a scoop to the roof portion of the spyder to hide the rear view camera. My first inclination was to extend the scoop from the front of the spyder at the windxcreen all the way back to the rear clip so as to not interfere with the aerodynamics of the car. Half way into the construction of the scoop I decided on a smaller project for the scoop and make it look more like,,, well a scoop. A styrofoam(floral foam) interior mold was made and the fiberglass laid. This is in its final stages and is being finished. I then wondered what I would do with the top since I had already sanded a large portion of the top. The car was going to be repainted anyway, but budget restrainsts make that a project for next year.
I had stumbled onto a Utube set of videos that used a product that basicly was a ruber based product. Some of you have probably used this product to coat the handles of your pliers, cutters etc. The product is known by the name Plastidip.
It comes in rattle cans as above or in containers so it can be sprayed.
Some of the imports are using this to completely cover their cars, wheels, emblems, dash parts, stripes, etc. Once setup it can be washed with pressure washers etc. with no ill effects. It also can stand up to heat(exhaust tips of standard exhaust pipes). The unique feature of this stuff is that if you don't like it, or you want a different color, you just peel it off. The claim is that it won't hurt the paint or clear coat on the car. At dipyourcar.com
https://www.dipyourcar.com/home.php
they have numerous videos on how to use the stuff and the tricks to getting it right. Lots of experimenting going on there. They are broadening their product line to include Pealizerss, Metalizers(gold and silver) and clearcoats known as Glossifiers, which can give the matte finish a satin apearance. The basic color is a matte black. Other colors include gun metal grey, white, red, camoflage colrs(greens and browns), and some electric colors. There is some work going on combining the sprays as they are aplied to get different effects(the peralizers with most of the colors) and colors. They even have a choose your color setup with the basic colors that can be mixed in a clear base by themselves or together to give just about any color you can imagine. Visit their site to see what is going on. They are also using the clears for bras on the front of the cars for protection against insects and minor dings. Not bad for $6. All of them can be painted over, but it makes the peeling off a chore.They offer a complete car setup with the sprayer, respirator, gallon(s) containers of the stuff and a few extras for under $300. You can use regular hvlp units but theirs is an electric sprayer that they are getting great results with.
Back to my car, since the top was already partialy sanded I decided to try this stuff out and see if it was as good as the videos claimed. Here is the top of the spyder.
Here are the finished results. The rattle cans(what I used) come thinned out to what they say is a good consistancy. The cans have to be shaken often during the spray process, and they give a good fan pattern. The gallon conainers need thinners to be added to get the proper consistancey.
These shots were with three coats. New coats can be aplied 15 minutes after spraying. They suggest 4. Also the imperfections need to be out of the way. I didn't level off the areas where the stripes were and their height differences can be made out, but it does make the car look a lot better.Different colors can be sprayed on top of other colors. The tape doesn't pull it up when removed. Just have to do it while the stripe surface is wet. They have videos on that as well.
![P1010180-1.jpg](http://i282.photobucket.com/albums/kk242/Billmusarra/P1010180-1.jpg)
![P1010156-1.jpg](http://i282.photobucket.com/albums/kk242/Billmusarra/P1010156-1.jpg)
![P1010167.jpg](http://i282.photobucket.com/albums/kk242/Billmusarra/P1010167.jpg)
![P1010162.jpg](http://i282.photobucket.com/albums/kk242/Billmusarra/P1010162.jpg)
![P1010168.jpg](http://i282.photobucket.com/albums/kk242/Billmusarra/P1010168.jpg)
![P1010174.jpg](http://i282.photobucket.com/albums/kk242/Billmusarra/P1010174.jpg)
![P1010177.jpg](http://i282.photobucket.com/albums/kk242/Billmusarra/P1010177.jpg)
![P1010173.jpg](http://i282.photobucket.com/albums/kk242/Billmusarra/P1010173.jpg)
