I'm running a Roush 427IR with eight stack injection and megaphones. Thought I'd share something that others might be experiencing...
Ever since I got my car on the road last year, I felt it was a bit of a challenge to drive - mostly in a good way. But there has always been a engine lugging, chugging, pulsing, and general unhappiness below 2200RPMs. I lived with it for a while because I thought it was just the nature of the beast. After driving it for a year I finally decided that a 568hp engine with 540 ftlbs torque in a 2400 lb car simply should not lug/chug/pulse as much as mine did. I'm not the world's greatest driver, but this car should simply not be that hard to drive well...
Called up Roush. They had Chad, their FAST expert in town last week and asked me to bring the car over (the advantage of going with a local engine builder!). Chad hooked up his laptop to my car and off we went for a drive. Through his wizardry, he was able to smooth out the chugging/lugging live as it was happening. It was amusing driving around Livonia at 20MPH intentionally trying to get my car to lug. Apologies to all the drivers behind me that thought me an idiot. (No hazard flashers on a GT40 that I could find). After about 20 minutes of doing everything I could to drive badly, Chad had all the rough spots smoothed out. How he managed to sit sideways, work intently on his laptop in a closed cramped cabin and not spew cookies as a result of my intentional bad driving is a talent equal to his skill with the FAST system.
Apparently the design of our collectors and my megaphones are the culprit. The leaky fittings allow fresh air to hit the O2 sensor at lower RPMs. When the O2 sensor smells fresh air, it apparently responds by dumping a ton of fuel into the system. Above 2200RPMs the engine is pushing out enough exhaust to keep the fresh air out of the system, but below 2200RPMs was the problem. Chad managed to override/change the FAST system's reaction to fresh air below 2200RPMs and made a few other minor tweaks.
I was also getting occasional stalls when transitioning quickly from higher RPMs to zero throttle when approaching a stop sign or turn. A quick tweak of the throttle plates corrected that problem. Apparently the throttle plates are set somewhere between 20-25 degrees. Opening them a touch solves the stall problem. Apparently more of an issue with cars that are always running the AC.
The result is a gloriously more livable GT40! The only downsides are it does not snap/pop/backfire on downshifts like is used to. The rough running below 2200RPMs also made the motor sound a bit hairier than it really is It was unexpected when I first drove my car to hear the occasional backfires on downshifts - did not think a EFI car would do that. Apparently now I know why it did. I wonder if I can get Chad to put that backfire back into the program while preserving driveability
A thank you to Mark, John, and Chad at Roush for getting things sorted so quickly and easily!
- Jeff
- Jeff
