OK Guys,
Am laying out the fuel system and considering the parts to be used. Is for a 351W engine that dyno'd 506 fwhp.
Thought I'd try to acquire a Mallory pump and pressure regulator. I'd route hard line from the tanks to a "T" through a directional check valve on each side. Then to the pump with SS wrapped tubing and from the regulator to the carb fuel rail with the same.
A few questions:
1) Is copper a no-no for fuel hard line?
2) Swage-locs OK for compression fittings?
3) Anyone identify a source of reasonably prices check valves?
Any other insights on other things that should be in the circuit other than an inertial switch for the fuel pump?
Thanks,
A few questions:
Thanks,
