Got the gas springs/struts installed on the rear clip, but think I ordered them with way too much pressure. Ordered two 125 lb struts. Clip definitely stays in place in the up position, but takes a lot of prssure to push into closed position, and when it gets to closed, it immedaitely starts to go up unless it is latched in place or you hold it down.
What "poundage" gas springs/struts are folks using to easily lift rear clip, hold it in place, and then easily lower on to latching pin?
Thanx
Mark
Thanx
Mark
