Mick:
Great job on your chassis, its a shame a lot of it will be covered at final assembly.
I totally agree with mounting the radius rods inboard at the front as it does make for better geometry at the wheel, also after doing many of these type suspensions I have found that keeping the radius rods as close to equal length as possible is essential.
This means staggering the fore and aft positions of the mounts, with the lower being slightly forward (to compensate for the difference at the top of the upright and lower wishbone).
I planned 5 deg. positive caster into my rear uprights and made the mounts accordingly which resulted in greatly reduced toe change through suspension movement.
Also, my lower radius rod has a 2 deg. rise from the lower wishbone to the forward mount to introduce a bit of anti-squat into the whole design.
I am running 14" wide wheels at the rear with 5" backspacing, and so far the setup looks to be as neutral as I can get it.
Nice build, keep the photos coming
Phil
Phil
