Re: Possible Suspension Arm Failure, Racing - Tornado GT40
Don´t think so.
my opinion,
Yes use the "soft shock stop" before the "hard" spring coil. But if your spring is to soft and therefore the car is overriding it permanently, the soft spring stop will be overloaded as well and than it basically results in the same load to the other suspension components as with a coil bound spring.
Both components need to be designed correctly first and than the suspension component like A arm than need to be designed according to the resulting load.
Again also i fully agree that this resulting load is very depending on driver , road condition, how the car is used (abused) and therefore designing a failsafe component is a big challenge, especially when you have to take in account also economic parameters ( what is your clientel willing to pay for).
Just take F1 with almost unlimited budgets and engineering ressources. How often do you hear of broken suspension components ( just have the picture in mind of the car which broke both front a Arms at braking into a corner). They have all the datas, the software, the knowledge to do it x times better than any of us, but still they fail to succeed, because they take other parameters into the calculation ( like weight, aerodynamics an so on) which compromises the design of the suspension component.
I once testdrove a brand new Audi A4 3.0 Quattro. At parking the car in front of the dealership i slightly hit the boarder of the parking space ( did not damage tire or rim) but the lower wishbone broke. After analysis we coud see that it already had a crack before ( oxidised aluminium). So either that was a manufacturing issue or someone have damaged it before.
TOM
I think Jac already did that...
Don´t think so.
my opinion,
TOM
