"How do the GT40s compare in handling and OR lap times to some of the modern cars you guys are running with out there?" (i.e. E92 M3 - 997 Carrera - Lotus Exige etc.) Im Assuming it handles Fairly the same Because of the weight advantage?? Is that wrong!?
I understand the advantages and disadvantages because of the differences between the cars on an engineering and technological front; (i.e. when it comes to the active gadgets in the engines and the suspension components) but the GT40s you guys run have full race coil overs and weigh significantly less (roughly 900 lbs less than the M3, about 500 lbs less than the Porsche... 400 heavier than the Exige...although heavier in this case the GT40 does have 2 times the engine power typically)
Anywho, My assumptions are based on my readings that the GT40 weighs 2,500 lbs with engine and trans... if Im wrong let me know what might be a good estimate. Either way... how does it compare? Anyone?? anyone?!??!
?!??!?!?? Just curious
