I am building two of these at the moment , not intended for the road but just for the odd track day /hill climb although they will be road registered .Initially the plan was to build one to use up all the 302 bits and pieces left over from messing about with these engines but a friend decided he wanted to play so there are two. Initally I purchased a part built chassis for £50 just to see what the implications were for fitting a 302 in such a small frame, I was surprised by how much room there was around the engine, the problem area is the gear tunnel. If you go for any of the standard trans/flywheel set ups the engine sits way to high and has to be pulled forward so much that the chassis would need stretching but with the quartermaster clutch/flywheel setup a smaller bellhousing can be used with a rear entry starter and there is no structural mods needed to the chassis . 302 ford engine with target of 350 hp, gearbox choice is the Getrag 265 dog leg direct top and the rear diff will be BMW large case.Should be a hoot in a 750kg car. That 302 engine with ali heads ,manifold and flywheel/clutch set up is lighter than a four pot pinto :stunned:
Enjoy and criticise please:laugh:
Chassis frames.
Quartermaster flywheel and a triple plate clutch will enable the engine to be lower in the chassis and shoved back.
Chassis frames.
