The Holley Red will be fine. You will still need the Holley low pressure regulator. I have ran Webers for a long time. If you have any questions let me know. I might have been there before.
Thanks guys!!!!
I am working on a Pantera with webbers and a mechanical pump.He rerely drives the car (every three weeks) and when he does,it takes a bit to get the bowls filled up so it will run.
I thought a electric pump would do the trick.
Carter has a rotary pump that is preset to about 3.5 lbs, it puts out enough volume for the webers and will not over power the floats. I run 2 of those on my CAV and they work very well.
