Ken Roberts
I'm doing some initial alignment adjustments to the front suspension and came across this observation.
The drivers side upright sticks out farther than the passenger side by approx. 3/8". If you were to draw an imaginary centerline for the chassis and then measure out to the tub wall where the upper and lower control arms bolt to you'd find that the passenger side measurement is 3/8" less than the driver side measurement. I'm sure this would be caught when you attempt to do the string line measurements.
Has anyone else observed this? This means that the drivers side upper and lower control arms must be initially adjusted in farther than the passenger side. Driver side should be moved in 3/16" and the passenger side moved out 3/16". This is assuming that you started with both sides the same.
The picture is showing you that this particular measurement is not the same from one side to the other (3/8" difference). I have a 4' straight edge running along the side of the passenger tub.
