Jay,
I have built a GTD over the last few years. Fitting the panels was certainly not the hardest job and I did it twice! Mine came pre-cut and pre-folded although they didn't fit perfectly so there was a process referred euphemistically as 'dressing', which meant filing and occasionally re-bending them to fit neatly. I would consider either getting flat sections and a folder or making your own from scratch - but then other sources may fit better to start with.
After having fitted them the first time (including sikaflexing - rubber sealing compound) I didn't like the look of the polished ally especially contrasted against the black rubber piping supplied, so I took them off (very difficult), cleaned them up, and had them powder coated in semi-matt black. This also makes them much more original looking and has withstood a few months (1,000 miles) of road use. Its a plastic paint and very resilient.
If you use 'pop' rivets you have to be sure they are blind sealing types to avoid rather a lot of leaks into the cabin and chassis rails. I have so far preferred to use black screws but if I can locate some black anodised suitable rivets I'll change them.
In conclusion if you have basic home DIY skills you should not fear fitting these panels, its time consuming but not that difficult. Good luck.
David C
