As part of changing stream half way through my build I now have a problem with my intake manifold.
Iniitially i was going to build a 347 but have since decided to go to utilize the long rod 351W which is sitting under my bench.
I had sorted out my intake for the 347 and was planning to use a modified Hilbourne intake with EFI type injectors in it.
Now that I have changed direction, I have to do something about an intake and my first thought is to mill up a couple of adaptor plates to allow me to use my existing manifold on the 351W
I am sure someone has done this before and will have the necessary measurements that would be a good place to start.
The other option is if some has modelled the Ford blocks in AutoCad or SolidWorks and may have enough info to derive the measurements.
I have included a picture of my manifold
regards and thanks
Kevin B
regards and thanks
Kevin B
