What fuse panel/harness did you start with?
Joe, I’ve ordered a set from Tornado (Andy) which I’m waiting on a batch to be finished up in January. You might want to contact him and see if they are all spoken for or if they have a set available for you.other than RCR who sells the hartwell latches?
thank you
Im honestly not sure of the spring rate, chris supplied them. I can find out though.Joe, I’ve ordered a set from Tornado (Andy) which I’m waiting on a batch to be finished up in January. You might want to contact him and see if they are all spoken for or if they have a set available for you.
BTW did you see my post about what coilover spring rates? What pound springs are you using for your car front & rear?
Devin
350 frontJoe, I’ve ordered a set from Tornado (Andy) which I’m waiting on a batch to be finished up in January. You might want to contact him and see if they are all spoken for or if they have a set available for you.
Devin
Not at all, Im very happy with it.the spacers I needed in the front to clear calipers gave the car a better stance aswell and fits well better.Would you do anything different with your wheel/brake combo if you were to do things over? I've been talking with Chris and ET Mags trying to get something figured out. It seems like brake caliper clearance is tight with the AC wheels.
I don’t on a strait on view, if you zoom in pic I don’t have the rear on.I’ll pull off tomorrow and send you pics of my exact setup from spacers to wheel without knock offJoe...do you have a picture of the wheel without the knock off on it? I'm thinking about going with bolt on and exposed longer wheel studs and lugs.
The trigo adapters might actually work because technically they become the spacer.question is, would you be able to get front set a lil thickerI'm sure it is probably a no-go, but I originally wanted to go with pin drive, but not sure i could make that work with spacers.
