Ken Roberts
I added a oil temperature sender to the dry sump tank for the GT-R. The sender used on C6 and C7 dry sump Corvettes is AC Delco #213-4333 (GM#12608814). This sender is the most common size found on current GM vehicles. It is used for the coolant temperature as well on LS engines. It uses a M12x1.5 thread pitch (straight thread). Trying to find a weld in bung is very difficult in this size so I bought a tap and made my own. It's very important to have the hole and threads tapped/drilled at a perfect 90 degree angle as this is not a tapered pipe thread. The crush washer provides the seal. You might want to make a couple of these. I plan to put one in my LS9 supercharger coolant tank as well in case I want to monitor the coolant temps. (shown in the third picture). Keeping an eye on the IAT temps is important with boosted motors.
Tap-https://www.mcmaster.com/26015a612
Spacer-https://www.mcmaster.com/1610t11 (1/2" length)
Drill bit-https://www.mcmaster.com/2901a171
Connector pigtail-https://www.rockauto.com/en/parts/acdelco,PT1798,temperature+sender+/+sensor+connector,2564
Sensor-https://www.rockauto.com/en/parts/acdelco,2134333,temperature+sender+/+sensor,4748
