Mid Rise Scissor Lift
Davidmgbv8
Building a Southern GT40. Looking at scissor lifts however it appears that most are 4- 5/16" to 4-3/4 height. I did not want to put one in the floor. Is the GT40 just too low for these? Any thoughts out there?
Phil G
Yes it is a bit too low so I just ran a 2x4 with some ramp ends attached. The back piece is rubber and stops it from sliding.
Scott
I dropped mine into the floor and I love it. Drive anything onto it and simply lift. When you're not using it, you basically gain a parking space. You also don't have to worry about tripping over the hydraulic lines or balance lines. If it's your house and you'll be there a while, I'd consider dropping it into the floor. A pain in the ass, but 2-3 guys can do it over a long weekend if you rent a gas-powered masonry saw to plug cut the floor.
Brian Kissel
I just ordered one of these. Should be here by Christmas .
They make a model that mounts above ground and has small ramps on the ends also.
Regards Brian
Larry L.
Regards Brian
Wow! $9K!
As I recall, that's roughly what I paid for my double-wide BendPak about 7(?) years ago!
I'm now at the stage in life were I understand why my grand father was upset about the cost of things in his twilight years... ;-)
All that said, if I knew where I could get a genuinely waterproof scissor lift, I'd get one. 'Would sure make power washing undercarriages much quicker and easier...
Brian Kissel
Larry, that lift was $6170.00 in May. This whole Covid thing has driven prices through the roof.
Regards Brian
Julian
I have a 6k mid rise scissor lift and built a pair of ramps from 2x4 to drive over and retain the parking space for low ground clearance vehicles. I have a 4 post lift as well, but the mid rise has truly been the most useful addition to the garage I have made.
